- Apr 7, 2019
So I managed to get my W3690 to 4.2ghz at 211 BCLK x 20 at 1.36 VCore and 1.34 QPI, with my IOH set to 1.18.
It's rock stable, runs well, I'm pretty happy with it. The temps are nice and low (mid 70s) at full load on small FFTs on Prime 95, and the voltage is acceptable.
BUT I live in a first world country, therefore I want first world speeds dammit - I want 4.4-4.5 ghz.
My last attempt 4.4ghz I had my settings at 211x21 for a frequency of 4.431ghz - Vcore at 1.41 QPI at 1.35. Boots up fine, runs Prime 95 for about 45 minutes before crashing and giving me a BSOD code of 124, which according to bro science and old forum posts means that I should raise my QPI voltage. We all know that a "safe" QPI voltage for the X58 platform is 1.35, so the question is, should I raise it? This is an old chip, and replacing it wouldn't really be a big deal, but I've never broken a CPU overclocking, and I'm not about to start now. Is there a trick to pushing past this limit on the W3690? I'm running 24GB of RAM at 1693Mhz on this thing spread over 6 sticks, and from what I've read using all 6 RAM slots makes things a little tricky. I can't confirm on whether or not that's actually true, but the fact that the BSOD I got is suggesting I raise QPI voltage even though I didn't raise the BCLK to achieve a 4.4ghz overclock might make sense - I dunno. The fact that I got it to run Prime 95 for a little while would suggest to me that achieving stability is most likely possible.
A penny for your thoughts.
