Hello everyone. My friend and i have been arguing over who has the best looking system. We both have constructed the systems with low budget in mind and i know other rigs look mindblowing but this is between me and him.
System specs:
AMD system - amd phenom 2 x6 3.0ghz
- 8gb ram ddr3
-AMD HD6990 dual gpu watercooled by handmade loop
-Corsair AX850 psu
-etc
-note : the cooling has a closed loop between the 2 gpu's , their vram , gpu vrm and a 240mm aluminum cooler in the back of the case then back to the pump
Intel system - Intel dual core G series @3ghz
- 4gb ddr3 ram
-Nvidia GTX660 overclocked so above spec wattage I guess
-@ 500w psu
-hybrid water and air cooling adding redundancy in case of a malfunction
-note : the cooling system cools both cpu and gpu by air and each cooler has waterpipes running thru taking heat from the system to the outside into a recipient that is not sealed and is recirculated by a pump of course. This system seems to run quieter than my system because of fewer fans.
Intel rig
Amd rig
If an admin thinks this is not in the right place he can move the thread to where it must be. Also i would like a poll added but don't know how. Intel rig vs Amd rig.
System specs:
- 8gb ram ddr3
-Corsair AX850 psu
-etc
- 4gb ddr3 ram
-@ 500w psu
Intel rig
Amd rig
