- Oct 15, 2001
- Tennessee
I don't think it is an SMP compatibility thing. I think they just aren't the fantastic overclockers that you want them to be. You might just have to settle for 1900-1950 MHz.
What exactly happens? Do you get a lock-up with both CPUs installed?Xtc4u said:I'm trying to get my 1700 chips over 2.0 Ghz but its proving impossible. I know they can singly but as soon as i put the second CPU in the board they crap out.
I ask again only because some K7Ds have a flaw in their power-delivery circuitry that causes them to lock up with Thoroughbred B and Barton CPUs starting around '2400+' speed (as these CPUs draw more current than Palominos and Tbred As). If you get lock-ups around 2032 MHz -- but can run each CPU substantially higher than this in single mode/another motherboard -- you're probably suffering from this design flaw.ZaP37 said:Do you get a lock-up with both CPUs installed?
cmcquistion said:
I disagree. I think his problem is that he just hit the limit of his chips. I haven't got any XP1700's over 2 GHz on a dually, either, but I've got a pair of Bartons that will do 2250 (with a lot of Vcore). You just can't expect as high of an overclock on a dually rig, as you could get on a single.
I have NEVER heard of a dually that could overclock it's chips as high as those same chips could overclock on a single-CPU platform.
Audioaficionado said:
Do you think I'll have any problems getting my XP->MP2400s to run at the rated 2GHz @ stock vcore before I overclock them?
Certianly red, but possibly green as well. MSI K7D Master-L 030 is one model that I know is affected, but I think I've heard people with non-L Masters having the problem too.Audioaficionado said:Was it the old style green or newer red PCBs?
The power-regulation problem can be identified by the presence of complete lock-ups during load. Did you get freezes with the 1700s? (I'm betting no because if you did, it would be impossible to run Bartons @ 2250, as they would probably use even more current than 1700s at 2GHz)cmcquistion said:I disagree. I think his problem is that he just hit the limit of his chips. I haven't got any XP1700's over 2 GHz on a dually, either, but I've got a pair of Bartons that will do 2250 (with a lot of Vcore).
TLhead said:The issue that ZaP37 mentioned can be real....I've had this problems with two K7D's now....The one I originally bought and the first RMA I got from the. Both boards would run true MP2000's undervolted and underclocked to 1.6V and 1.4GHz, but at stock would lock up with 100% load immediately....I was going to just put up with it after RMAing once, but the problem kept getting worse.....Anyway, I bought an ASUS board off ebay for 120 bucks, and RMAed the MSI again....The ASUS runs great! it's so nice to have a stable computer......I just thought I'd put this out there.....It does sound like your CPU's are at the limit to me too.
