http://www.xtremesystems.org/forums/showthread.php?threadid=34565
Hmmm, stumbled across this while studying from other peoples success/failures.
This will be my last post on the subject:
I dont have that much " time " anyways, to waist on building a few water chillers and whatnot that will just be tossed out. Believe me, if something bad happens, not much will be lossed.
I wouldnt call myself a moron though, i do have good understanding about how these things work, moreso than most people.
I know that some oils work with some refrigerants, while others wont.
I know that at certain temperatures, you will need an oil seperator, which comes before the condensor, and feeds back the collected oil to the comressor through a cap tube with a solenoid valve to limit flow.
I know that these systems are very dangerous, and if not treated properly, can/will kill.
I know that in order to achieve a safe, well working system, refrigerants will need to be mixed and some refrigerants cant be used. To help thin the oil, to help with pressure, and other reasons, you need a mixed system. I will need lots of help with this part.
I know that you need to remove all contamenants from the system
I know you need a dryer, comes before cap tube, after condensor
I know that you want the flow to go:
1.) From compressor, to top of condensor.
2.) Top of condensor to bottom of condensor.
3.) Bottom of condensor, to dryer
4.) Dryer to cap tube
5.) cap tube to evaporator
6.) evap to loops to prevent liquid from returning
7.) liquid loop trap thingys to compressor.
I know that on the guages:
yellow goes to refrigerant
red goes to "head" or high pressure side (before condensor)
blue goes to "suction" or low pressure side ( after evaporator )
ahhh, i guess i will post more, on what i know/ dont know because im really tired now. later
