Hey people , is the FX-6300 compatible with this http://www.comtradeshop.com/maticne_ploce/asrock_mb_-_socket_am3_-_960gc-gs_fx-23601. I know its not ur language but u can see the specs . And i heard that its compatible but ill have to install update to bios from flash ? Every help is welcome , and if some1 had this case all tips are appriciated . And the one more thing , will i be able to use both ddr3 and ddr2 ram at once ? for example i put 2x2gb ddr2 800 mhz and one stick of 4gb ddr3 , it would work ?
