brokencarr00t1
- May 14, 2014
Hey ive just overclocked my fx 6300 from 3.5 ghz to 4.3ghz. When i overclocked to 4.3 ghz first time i had voltage around 1.400 , but now ive tried to lower to 1.300 and its works , pc dont crash. Now i wonder should i go lower in voltage to see how much voltage do i need for 4.3hz? I mean is it good to try lower voltage to see if will work with 4.3ghz? Is it safe ?
When overclocked to 4.3 ghz with 1300voltage my temps are IDLE around 37c and when running prime 95 around 49c.
Im using sabertooth 990fx r2.0 and have a cooler master hyper 212.
Also when i set minimal voltage to this speed i was plaining on raising voltage and speed more than 4.3 , 4.5ghz for example.
need advice on this ! Thanks
