thecreatorst
- May 28, 2015
Hello all, I am new here and in the overclocking scene in general. I have built a couple pc over the years but for the first time i am trying to overclock. My pc specs are
Cpu: fx 6300
Mobo: gigabyte 970a ud3 rev.3
Gpu: Radeon hd 7870 xfx
Ram : 8Gb (2x4) corsair vengeance
Psu: Corsair cs450w
Cpu cooler: Cm hyper 212
On to my problem. I read a lot before attempting thisso i can avoidany unwanted consequences. My cpu runs oretty cool with no Oc uner prime (about30- 33c).
I have disabled all of the power saving options on my Mb, and atempted a try at an oc, but even from the very low frequency of 3.7Gh my cpu is throttling. Whenever i run prime 95 cpuz shows my frequency dropping at 3Ghz very frequentlr and the jumping back to normal, and mu multiplier does the same dropping to 17 before going back to normal. Kastly the same vo!tage is a!so a bjt unstabke but i think not by a lot. I can check as soon as i get home if you believe tgat matters.
My temps never exceed 42c at max and which makes sense as it reaches higher speeds when not oced.
I run windows 8.1 and have set power settings to performance.
Lastly at stock the cpu seems to run fine under stress test with the frequency ranging from 3,5 to 4, i guess because of the enabled turbo mode.
Any heheellp or feedback wiuld be appreciated as i have no experience and am stumbled as to what my next step should be.
P.S. needless to say i have nly tinkered with the multiplier.
Cpu: fx 6300
Psu: Corsair cs450w
