- Mar 18, 2013
- Finland, Etelä-Savo
Hello!
I bought an ADM FX-8120 and a MSi 760GM-P32 Mobo. It took some time to get it to work, since I had to do a BIOS update before it agreed to co-operate.
So, after installing all the drivers and getting things to work, I ran Cinebench. I scored only 3.02, which is too low. Then I checked the temps, just to be sure, and I was greeted by very unpleasant numbers. Idle temps are reported to be 25 °C, but under load the temps go linearly up to 45° and then jump to 206°. I checked the temps by hand from the heatsink. It was warm, maybe 45-50°. That shouldn't be too much for this processor.
The multiplier drops to 7x and the core voltage is reported as 0.9V. However, I don't trust the core volts since the stock volts are reported as low as 1.15V. This of course has "some" performance impact.
Turbo is turned off and so are all Power saving stuff (C'nQ and C1E) from the BIOS. All drivers are also up to date. I also tried rolling back on BIOSes and chipset drivers, but that didn't help.
What on earth am I supposed to do?
