Don't use the "Pro" version of HWMonitor unless you pay for it. It's only free for a limited time trial use and then it starts to close off some features and block them.
Barocco as Trents said try not to use HWMonitor Pro as it shuts down the features and Blocks them! This is the one to use and Download and keep? AJ.
1, http://www.cpuid.com/softwares/hwmonitor.html
RGone and Trents Merry Xmas Guy's and Trents take it easy buddy after your Operation!
Thanks for info apreciate it: will stress with prime95-torture test,monitore with HWMonitor and AIDA64 OSD(ON SCREEN DISPLAY) to monitore my temp.then i will edit pictures of all my temperatures to se it it is realy ok and if system is stabile.Usually we look at pics of HWMonitor under load or under stress for the Min and the Max values to determine if temps are okay. I don't think that HWMonitor capture is done while the system was loaded. Otherwise it looks okay. Good fortune to you.
