Hi,
I have ASUS M4A89GTD PRO/USB3 and I bought new cpu - AMD FX 8320.
Now I have problem with stability of cpu frequency and voltage. When I run Prime95/IBT cpu voltage and freq drops down to 1.2V and 2.9GHz. All power saving options in Bios was disabled. What's the problem?
This motherboard should be enough for this cpu and give to it enough voltage. When I set cpu to 2.5GHz the problem is gone and frequency stay stable at 2.5GHz. While I had Phenom II X4 955BE I testi it on 1.55V and frequency and voltage are ultra stable - no Vdrop and anything else.
As such, he used a lot more energy then the current processor FX 8320.
MBO: ASUS M4A89GTD PRO/USB3
GPU: EVGA GTX 770 ACX
CPU: AMD FX 8320
CPU COOLER: Corsair H60 (2013 Edition)
CASE: Cooler Master HAF 922
(Fans: 3x 230mm, 2x 120mm)
RAM: Kingston HyperX blu. 8GB 1600MHz
PSU: Thermaltake Toughpower XT 775W
HDD: WD Caviar Black 500GB
MONITOR: Philips 247E3L LED
OS: Windows 8.1 Pro 64-bit
CPU: AMD FX 8320
