Maybe? Need more info....I am guessing I need to reinstall windows. I did a little research and a few people going from a 4 core to a FX 8xxx are having this issue. Am I correct?
Is it? We dont know much here. Im pretty sure its one graph or shows all logical processors, so task mananger wouldnt show four (like he said hes seeing) then 8?hey don't worry its typical Windows bad programming. If you go to Task Manager - Performance - CPU and right click the graph you can switch the view to Logical Processors, it will show you something like this - 8 cores
just saying task manager only shows the cpu as one or all of its logical processors (threads). It wouldn't show 4 then 8 by making that change...the graph or cores and threads.
