Hello all,
I have recently upgraded my computer to a FX 8370 and I'm having some issues as temps in load will average around 60-65 with peaks of 70-73.
It has the stock cooler altough I have already bought a Cooler Master Hyper EVO 212 which I'm planning to install ASAP.
However something happened today that made me question if it was just a temp problem: I played a game (not cpu demanding) for a couple of hours and according to Hardware Monior Pro cores were working at 1,4 mhz and the temp was around 25-30, which was right as I touched the case and it was cool.
However when I played it again a couple of hours later the cores started working out of the blue at full speed (4,3mhz) and the temp went up to 60-65 which is what it averages on more demanding games.
The mobo is an ASUS M5A78L-M_LX_V2 which is the one that I had with my previous CPU and according to the manufacturer it is compatible with the FX 8370.
However I'm unsure now if the problem is the stock cooler, the mobo or both.. I don't know if it's worth something but usually the VCORE peaks at 1.45 altough I can see no relation between it and the cores' temps
If anyone could give me any kind of advice I would appreciate it.
