- Apr 19, 2012
@1.5250v and more, what liquid cooling would bring a true equilibrium to his set up disregarding the motherboard and Power Supply?
Tempted to drop mine in a fish tank....
...forgotten this thread when I was going back thru the AMD Motherboard Section.
This user came into another thread that had gone dead and was asked to start his own. He did and was worked with to GET BACK TO STOCK settings. He then reported all his crashing was GONE. Look at the setup.
MOBO- sabertooth 990fx r2.0
CPU - amd 9590fx black - with water cooler (came with the processor)
Now I certainly do not recommend the cooler used in link above. I like to PLAY with my overclock and settings but without EXTREME COOLING one cannot do that with an FX-9590 it seems. So run the cpu as AMD designed it to be run and stay out of the bios and use the rig.
I am going back thru all the FX-9xxx threads in the AMD Mobo section since there are more of them in that forum section.
This was a younger user going to college and we had "fun" in his thread. OT more than once but got him sorted. COOLING was KEY.
AMD 9370 issues with Crosshair Formula V - Z < Finally got his sorted with full on W/Cooling. To clock up with ALL 8 cores running.
RGone...
Looks like the guy fixed his problem by doing two things: reset the CMOS and make sure the cpu gets 1.5v?
I would duplicate EXACTLY what androshalforc did and not what you thought you read since he did not exactly clear the CMOS as you read ShrimpBrime asking him about. Check it then under P95 Blend loading for at least 20 mins with HWMonitor open and logging temps and voltages. Then capture and attach that HWMonitor to the forum along with CPUz > CPU Tab > CPUz Memory Tab > CPUz SPD Tab. Four captures. Of course it is hoped you don't crash immediately under the P95 Load. IF it does crash the first thing I would try is to go into BIOS and take CPU LLC from AUTO and set to Ultra I believe it is 2 notches down from the highest which is like Extreme. That CPU LLC raised might allow enough cpu voltage under load to run P95 in Blend mode.
RGone...
There is no GUARENTEE on anything.
Run it at stock settings, then it will turbo to 5 gig the way it's supposed to, but it won't be on all cores. Turbo only does half the cores.
If you want 5 gig on all cores you have to overclock to an extent, and maybe your particular CPU just ain't up to that task.
Okay, I understand, but can I get a recommendation on what I should do about a better cooling system?
Thanks for providing me all the information so far guys! You have all been a great help! I'm getting my cooling problem resolved with a custom loop, so I'm reading all about those ATM. In any case, I have a question about voltage drop. How do I prevent that from happening when the cpu needs it most? It seems to drop from the recommended 1.5250v but it seems to drop to around 1.2xxx v during heavy processes.
Nah, turbos only one core.
Set CPU Load Line Calibration on second highest or highest setting available.
1.52500v dropped to 1.2xxxxv is no good. This cpu should be around 1.4125v and up at stock 4.7ghz w turbo 5ghz sometimes will request up to 1.52500v. If you see a drop like that while running in manual mode, see above statement. If your running on auto OC, then see Bassnuts post 69 above and turn off C1E and Cool and Quiet.
I recommend trying to see how long it lasts at 1.487500v up to 4.9ghz no turbo manual OC Cool and Quiet off. If it hangs, more volts.
Side tracked.....
Shutting off 4 cores and try your overclock again. If you still recieve hang ups, 1.5250v is still recommended at 4.4ghz and up. However you may encounter less hangs with 4 cores off and less voltage, may also see less v-droop.
If you continue seeing a big V-droop, you may want to test 12v rails with a meter to be sure they are stable. 11.95x-^^ v ok, should be over 12v. 11.8v, you have a problem with the PSU. Should be tested while under full load conditions.
I thought you aleady were going to custom water cooling since you brought it up earlier in the thread? And I think earlier we asked about the CASE you have your stuff in because that surely determines what sort of cooling will fit. i don't see CASE shown in sigature.Secret Combo said:I'm getting my cooling problem resolved with a custom loop, so I'm reading all about those ATM.
