- Dec 1, 2016
New development.
I have just set up my Pi with a temp sensor and have it running and logging in the room with my PC's. According to both HWInfo64 and CPUID HWMonitor my CPU package temps are about 4-5 degrees below ambient..... Must be that Grizzly Kryonaught thermal grease overclocking my little wraith cooler
Is this likely to be the ****ty mobo causing bad readings? or should I be using the motherboards CPU temps?
The other machines in the room read idle temps above what the Pi says room temp is.
Fx 6300 gives false readings when below 40c after 40 it starts to give more correct values. I had same issue they would jump everywhere from 35 to 45 mostly and then just calm down on low 40-s.
I also had same issue with boot up system would also refuse to shut down properly or restart. It was vcore it was set too low when I increased it by one + and set LCC back to auto everything got to normal
