hi! wasnt quite sure where to put this as i have a couple of questions. i decided to overclock this cpu, knowing the kind of heat this thing throws out i bought a Thermalright Archon to remedy this as my old vendetta 2 just wasnt coping even at stock clock speeds.....it was getting up towards the 60C mark.
the Archon is a much better cooler and ive had the cpu to 4.6Ghz, but again temps become an issue, i cant run the CPU at full load. it just hits 60c in no time at all. i can game with it and temps are still a worry (hitting around 56C)
I took the side off the pc to see if it would help......it might have saved me 2c and that was it.
my case is nothing special at all. it has x1 120mm intake at the front, x1 120 exhaust at the rear and a 90mm rear exhaust that i bodged on and thats it!!
so i am wondering of i bought a better case would that put the temps down? or am i wasting my time? i would have thought if there was heat build up inside the case causing the high temps the removal of the side would have reduced the temps quite a lot?
im a fairly seasoned overclocker and know what im doing pretty much. for now i decided to just let the cpu run at clock speeds with the turbo core enabled......it seems to run at 4.2ghz all the time no matter what. i was under the impression it was supposed to run at 3.6 then jump to 4.2 when under load? anyway its sat idle at 33C at the moment.
so id be grateful for any thoughts and advice on the case thing and any other advice you guys have on this cpu!
cheers!
system specs
FX8150
AsRock 990fx extreme 3
8 gig DDR3 Corsair XMS3
Viper bronze rated 850w PSU
Gainward GTX470
cheers!
system specs
FX8150
Gainward GTX470
