- Nov 10, 2012
- Ankeny Iowa
IMO when looking at water cooling its FULL CUSTOM OR BUST. The H100 and TT Water 2.0 Performer etc are good units but you can get the same results with an equally priced air cooler. If you want to do a full custom loop the perfomance is limited only to your budget/willingness to expand it.
http://www.performance-pcs.com/cata...oduct_info&cPath=46_321_542&products_id=32616
http://www.performance-pcs.com/cata...oduct_info&cPath=46_321_535&products_id=26114
http://www.performance-pcs.com/cata...oduct_info&cPath=46_321_556&products_id=26691
As you can see there are quality heatsinks at alot of price points. The 212+ is recommended alot around here because of performance/cost. The noctura will beat it by a fair margin, but whether or not that 5-10C difference is worth triple the price or not is up to you.
