- Apr 20, 2004
- JAX, Mississauna
You need to return that cpu to where you bought it as failed or tell AMD rma that it is not reading temps correctly.
Like an idiot I did not keep the link to the ONLY user that has faced your problem in this forum for all the background info, but I basically remember and your cpu seems to fit the pattern he had. OH we have had others think they had they same problem as the ONE user I am referring to but it was because they had crap cooling and once that was fixed then their temps dropped. But remembering that only real situation; your cpu seems to fit his pattern and he had the CPU replaced and temps and all were then fine.
I am going to try and search for that ONE real thread that I remember that yours fits and will link it IF I find it again. RGone...ster.
Dang I hate this forum will not let me search my own posts back beyond 500 posts. I cannot go back far enough really to search like I wanted to do.
I am pretty sure the thread I was looking for was just about at the time of the FX-8350 release and that would put me needing to search all the way back into the 10th month. Crap0la.
I did find only the one thread or post where changing the FX-8350 out did lower the temps. Poster was martiNL spelled like that. BUT the one thing I did not remember about his circumstances was that his temps rose like a rocket to 70c and the board would immediately hard reset itself.
He never posted the screen captures we normally like to see but only wrote his temps and symptoms. So not as good an informational group of posts but that I do believe is the ONLY user that had immediate temp rise under Load that changing the cpu did bring reduce cpu temps and NO fast temp rise and KEY was he no longer had the hard resets either. So he truly had a problem with his Cpu that most don't have since their problem is just poor cooling.
He begins posting at post #7 in this thread.
http://www.overclockers.com/forums/showthread.php?t=720117&highlight=FX-8350
A couple or three posts he makes reading on down. You can read for yourself and see how closely your condition matches up to his. I do believe that was the ONE user post and rma that was warranted and needed. Like i said I cannot search my own posts as I wish so had to search backwards differently and I do believe that is the situation that was "in" my mind.
RGone...ster.
