G.Skill Trident Z Dual Channel not working on i9 and Z390
PzSniper
On 11th Jan after a week all pieces has arrived but ...got a big big problem... Hoping on your time and support, here's what happened.
i assembled my new pc, and here are the specs
INTEL CORE i9-9900K
ASUS ROG STRIX Z390-F GAMING
ASUS ROG STRIX RTX2070S A8G GAMING
PSU COOLER MASTER SILENT PRO GOLD 1000W
...but i can use ONLY 1 DIMM of my G.Skill Trident Z F4-3200C16Dm DDR4-3200MHz CL16-18-18-38 1.35V 16GB (2x8GB)
1 DIMM works B2 both of them if interchanged.
2 DIMM doesn't work in any combination b2 a2 or b1 a1...system start with MEM OK test, flash cpu red, flash yellow dimm led, reboot few times and then stop with 2 leds on solid yellow .
I dunno what to try after 5 hrs... already updated ASUS BIOS of ROG STRIX z390-F to the latest 1401 dated 11 Dec. 2019
ofc ram is listen on QVL for this mobo....
Please advice
Check the socket for bent pins. If no issues there, RMA the board. You've done all the necessary troubleshooting to eliminate other possibilities.
