Prodromo said:
How can one know if their heatsink will apply enough pressure after removing the IHS? Does anyone have any experience with a Swiftech Apogee and a cpu without the IHS?
If it's anything like the Swiftech Storm... it's VERY easy... just remove the mobo bracket, and SLOWLY tighten down each screw on your block. You can bolt it down snug, but don't do it too snug. Turn on your PC after and go into bios... if temp starts going up high really fast, turn the PC off and tighten a bit more... do that until temps are okay, but be sure to not tighten too hard.
My Swiftech Storm uses the mobo bracket in the instructions, which I used to use, but after IHS removal of my 148 a few months ago, I just took away the mobo bracket, and it worked out nicely.
Take your time...
*EDIT*
Forgot... to answer your ques about if a heatsink will put enough pressure is that they all will... you will either have shave down the mobo bracket to accomodate the change, or remove the mobo bracket, depending on the method of cooling.
Keep in mind that your modification will control how much pressure is put on the chip... it's up to the user.
*EDIT2*
I just remembered... yes, if your cooler is using the clips that clasp onto the socket, there will be less pressure iirc. You will still have to shave down the bracket, but there will be less pressure... even though there's less pressure, it still does better with the IHS off. That's how it was with my thermaltake smartboost.
MAKE SURE YOUR HEATSINK DOES NOT REST ON THE HUMP OF THE SOCKET. I feel like some heatsinks will. The hump of the socket is the side that the socket clip is connected to (not the side it's on, but the side it's latched to).
