- Oct 30, 2007
My specs
CPU: QX9650 C1 @ 4.0GHz, 333 x 12
CPU Cooler: Thermalright True 120 Black
RAM:OCZ Reaper 1066, 4GB OCZ2RPR10664GK @1066, 5.5.5.15, 2.2v
Video: PowerColor 4890PCS+@ 970 & 1120 in CF
MB:GA-X48-DS5 rev1 ( Gigabyte )Bios F7
HDD: WD 500Gb in Raid 0
PSU: CM Silent Pro 850 watt
DVD: Pioneer DL sata
Case: HAF 922 Moded with 3x 200mm RED led fans 1x 120 rear fan
OS:Windows 7 64 Bit
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .................: [Auto]
CPU Clock Ratio .........................: 12
Fine CPU Clock Ratio.....................: 0.0
CPU Frequency ...........................: 4000Mhz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...................: [Disabled]
CPU Host Frequency (Mhz) ................: 333Mhz
PCI Express Frequency (Mhz) .............: Auto
C.I.A.2 .................................: [Disabled]
DRAM Performance Control
Performance Enhance......................: [STANDARD]
System Memory Multiplier ................: 3.20B
Memory Frequency (Mhz) ..................: 1066
DRAM Timing Selectable ..................: [Manual]
Standard Timing Control
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP'.....................................: 5
tRAS.....................................: 15
Advanced Timing Control
tRRD.....................................: [Auto]
tWTR.....................................: [Auto]
tWR......................................: [Auto]
tRFC.....................................: 56
tRTP.....................................: [Auto]
Command Rate (CMD) ......................: 2T
Clock Driving & Skew Control
CPU/PCIEX clock control...............800mV
CPU Clock Skew ......................: Normal
MCH Clock Skew ......................: Normal
System Voltage Control...................[Manual]
CPU Vcore..............[1.25v]...........: 1.36875V
DDR2 Overvoltage........................:+0.40......... 2.2v
PCI-E Overvoltage........................:[Normal]
MCH Core.................................: +0.15V
FSB..........................................:+0.1 V
My issue is, when I try to run my sytem in Dual Channel config by installing RAM into DIMMS 1&3, 2&4 & 1&4 to get dual working my games CTD. If I run 3D Mark 06 or Vantage all is good with no crashes.
Why is this only with games, to over come this issue I have to run in Single Channel Dimms 1&2 or 3&4 to get my 4gb of 1066 Reapers to work without a hitch.
I have tried to run them in dual at 800Mhz with no success.
I have tried formatting system with no success.
Even tried all my stock setting SO NO O.C with no success.
If anymore info is required please ask. This has been an issue since I built the system.
I have seen on other forums that I'm not the only one with this issue.
Is anyone able to think of any solutions would be a great help.
OS:Windows 7 64 Bit
Clock Chip Control
