- May 22, 2011
- USA
If you're going to purchase a GTX 780 3GB, wait! for the 6 GB version. Should be here soon! Why pay $550ish when you can get the 6 GB for the same when it's released.
My brother owes me $500 by the end of the month. I'll add the other $50 to it and get the Processor, Motherboard and SSD. That'll leave me saving up for the GPU. Hopefully, by the time I gather the $520 for it, the new cards will be out.
With the introduction of the Z97 boards and incomming CPUs. How should I adjust my build? I understand if i get a Z97 board, my 4770k will work and I'll be able to upgrade again in the future. Is this recommended? Or, should I give it a few weeks and look at the Z97 processors as well?
I cringed when I saw that picture of a Hyper 212... It's not going to cut it for a 4770K OC man. Those chips run hot. A hyper 212 would barely cut it for a 2600K OC to anything reasonably high. 4770K runs significantly hotter and has TIM instead of solder on the IHS. You want a big cooler. Noctua NHD14 or NHD15 are my recommendations. Best air coolers around. The 14 is more compact, so you might want to go with that one. You'll get a higher OC at lower temps with a big air cooler. I don't recommend 212's to anybody these days. Not even for 4670K's. I recommended 212's back when the 2500K was the gaming CPU choice to go with. It made sense. For these new chips it just doesn't cut it in my opinion. Can you possibly return the 212 to the retailer? If not, you should be able to sell it online on either this forum or one more local to you, as "BNIB" for maybe $5 off retail price. Someone will take it.
Z97 motherboards are out now. You can buy a Z97 board, a 4770K, then upgrade to a new CPU some day down the line if you wish. Mind you, given the pace at which Intel is improving these quad cores, the next gen won't be anything too impressive. Things have been pretty stagnant in the mainstream sector since Sandy Bridge.
The new K sku CPUs will be coming out some time in the summer afaik. They are codenamed "Devil's Canyon". The non K Haswell refresh chips will be out much sooner. Just around the corner. You do not want one of these if overclocking is something you want to do.
I would personally go with something like a Z97-A from ASUS and a 4770K. And maybe consider a bigger cooler for your CPU.
Have you decided to hold off the SSD for now? That's cool. WD Caviar blacks are pretty peppy HDD's so you should get decent performance out of them. Once you go SSD you'll never go back though.
ntel has not released any of the new Haswell Refresh K series processors just yet as those are still a bit off. The Intel Core i7-4790K and Core i5-4690K are expected and are code named Devil’s Canyon by Intel. The Core i7-4790K is supposed to have a base clock speed of 4.0GHz and a max burst frequency of 4.4GHz, whereas the Core i5-4690K is expected to ship with a base clock of 3.5GHz and a max turbo frequency of 4.0GHz. These two 88W TDP processors are designed from the ground up for overclocking and have highly culled based on their overclocking potential. Other than being cherry picked as being good overclockers they also have an improved thermal interface material on them. The early rumors of Intel going back to solder appear to have been incorrect, but any improvement will be welcomed. If you are looking for a binned processor that was designed for overclocking we highly suggest waiting for the unlocked Devil’s Canyon processors to come out this summer. Word on the street is that these processors will appear around Comuptex, which would be mid-June.
Man, i wish you were around a few weeks ago. Lol. I bought it through Newegg. I've had it out of the box, just to look at it, but it's never been removed from the plastic shell inside. I've never returned anything to them, I'll have to look into that.
I'm still aiming towards the 840 EVO for the SSD. 250gb and then a Caviar Black as a storage.
I also want a wireless card, i know a few motherboards have them onboard, or i can get a PCIe wireless card. Which is recommended? Is one more cost-effective or performance-wise better than the other?
My router is downstairs, and I'm upstairs. I'd have to see where my room is in comparison to the router and running cat5e through the floor joists. It shouldn't be too difficult, except getting me off my rear to actually do it.
So, waiting on the cpu and waiting on the gpu.
Patience is a virtue. So I'm told.
You should be ok with the 212. Its a good air cooler. Don't know why there's such a backlash about it. Its closely comparable to those other CPU air coolers as well.
