- Jul 12, 2012
- Thread Starter
- #41
Um side note should I just take out that stick of 2gb to dual channel the 4gb?
That's a monster fan for sure. Hope you don't mind noise.
I don't...I ran fans that loud ~2ft from my ear for a looong time.
You still need an aftermarket heatsink that'll fit in your case.
Are you good with tools at all? Could just cut a slot for an intake fan. 120mm hole saw, a file, some dryer duct.
There's a trick you can do with a Molex connecter. You can change out the 12V wire for the 5V and run the fan at 5V, or wire the 5V to ground and the 12V in to run at 7V.
You know I was thinking what if I just got a new processor for my mobo? Say I didn't really care to OC it wouldn't that give me some kind of performance increase? And if getting a new MOBO to OC now that can't handle the next line of amd cpus I'd pretty much be wasting 80$ for just a little bit of boost if I OC.
Well I play on a 1080p monitor and I just can't play games like BF3 at decent frame rate (45+ fps) with high/max settings and resolution.What are you looking to gain, how is your current setup failing you?
Those questions have answers that can be given.
I guess I could OC I've just never OCed a CPU before so I don't know if I'll damage it or what. And I thought that microATX boards won't be able to upgrade to piledriver?Because it pays off more in the future. Stock Athlon II X4 to stock Phenom II X4 is a small-medium jump in performance, but an OCed Athlon II X4 to an OCed Phenom II X6/Bulldozer/Piledriver is a much better jump.
You either pay $100 for a small-medium jump in performance or $80 for a small jump and the ability to make a large jump in the future.
Well I guess I might just get the board. I hope it does indeed support the next line of processors because this would be a really good buy. Besides that would OCing my athlon be a worthy upgrade?It's pretty hard to damage a CPU while OCing. I don't think anybody knows for sure whether 8xx boards will support Piledriver.
