Totoro
- Mar 21, 2014
Hello!
I'm building a gaming PC and would be grateful if anyone could check my list of components and give me some feedback.
I'm not super concerned with cost (as long as the performance measure up to the price).
- List of components -
Case: Corsair Carbide Air 540
PSU: be quiet! Dark Power Pro 10 850W Modular
MoBo: ASUS ROG MAXIMUS VI FORMULA - ATX / Z87
CPU: Intel Core i7-4770K
RAM: Corsair Vengeance 16GB DDR3 PC3-12800 1600MHz (CMZ16GX3M2A1600C10) (2x8GB)
SSD: Samsung 840 EVO Series SSD 500GB SATA3 Basic Kit (MZ-7TE500BW)
GPU: ASUS GeForce GTX 780 3GB DirectCU II H2O Poseidon Platinum
Water Cooling
Pump: EK-D5 Vario Motor
Pump top: EK-D5 X-TOP CSQ - Acetal
Radiator: EK CoolStream XTX 360
Radiator fans: Cougar Vortex V12HP PWM
Reservoir: EK-RES X3 250
CPU Block: EK-Supremacy - Full Copper
Tubing: Masterkleer 13/19 Clear
Fittings: EK-PSC Fitting 13/19 Nickel
Coolant: EK-Ekoolant Clear
Is it a good setup, would you change anything?
I would like to be able to add an additional GTX 780 later on.
What about the water cooling, I've checked some guides and I realize it's a bit tricky, is it worth it?
The main objective is to keep the noise levels to a minimum.
I do have som previous knowledge of building computers but never with water cooling.
It would be fun to try it out though.
Oh, and I'm also thinking about adding some LED strips, any suggestions?
Water Cooling
