Hey guys!
I bought a Kraken G12, which is a GPU plate that allows for easy watercooling, along with a Corsair H55 (which will be used in push-pull). I intend to use it to replace the Aorus cooler on my 1080ti.
The Aorus cooler is pretty much ok, the GPU temps reach about 72c during Heaven, but the amount of heat it dissipates into the case is unreal. It also specifically releases the heat into an area that is very close to both the CPU radiator and the tubings (H80i). How bad is it? Everything inside the case feels hot to the touch after a sustained GPU stress test. I've actually reached the point that CPU temps peaked at 67c during 2 hours of Heaven benchmark! Heaven barely uses CPU power and the temp increase came from the GPU that is heating the H80i tubes and the radiator itself which does a lot of the exhaust.
So I thought, "hey, why not watercool it?"... I got a good deal on the GPU cooler, problem is I have no place on the case to mount the radiator itself of the H55. So I'm just wondering, let's say I just leave it near an exhaust area of the case, not screwed into anything (other than the fans) - will it generally work?
Thanks!
Thanks!
