- Thread Starter
- #41
I think you're right, because the pump itself when plugged "freely" makes less noise, it's still noisy but not as much. This narrows the list of compatible cases (for 240mm GPU rad) by a lot, unless I do front exhaust.I would guess you had air in the pump. The coolers have a little bit of air in them and you have the pump as the highest point so the air will collect there. That would explain the noise and the poor results. I read a few stories of people having problems trying to mount an AIO on the bottom of the case with a G10/12.
I would say the optimal setup would be to have a case with room to put the CPU rad on top and the GPU rad on the back both as exhaust. Then have front/bottom intakes. Or have two 120mm rads and mount them both on the front.
An interesting, general question now is, what should give better temps, a radiator mounted "freely" followed by exhaust fans (see first image on this page), or a radiator mounted in front of an exhaust port (standard mounting for radiators, see 4th image on this page for CPU rad as an example).
Radiator mounted freely -> extract heat more efficiently, fans run quieter because they deal with less pressure. Problem: may end up circulating hot air through the rad.
Radiator mounted on an exhaust port -> fans do more noise, air does not flow as freely through the radiator
