themightyrhino
- Aug 9, 2012
A few days ago I dropped my laptop. Upon startup, the Dell logo shows up but Windows 7 fails to load at all. After running diagnostics tests on the computer several errors came up for SATA disk.
I couldn't find the disk that came with my laptop to reinstall Windows but two years ago, I purchased a Windows 7 Ultimate upgrade from my university in order to upgrade my desktop from Windows Vista to Windows 7. I used this same disk to repair Windows on my laptop. I was able to create my login for my laptop but then I got to the part about typing in the product key. I tried using the product key that's on the bottom of my laptop but I get an error message that states "The product key does not match current Windows SKU." If I use the product key that's on the Windows 7 upgrade I get this error message "The product key is not valid" (I assume since it's associated with my desktop).
What's the best way to get around this or get a product key to work?
I also wrote down the error codes for the SATA disk if that will be pertinent at all.
Thanks.
Thanks.
