- Jan 16, 2004
- Murfressboro, Tenn
I just installed a Gigabyte GA-MA785G-UD3H with AMD Phenom II X4 945 Deneb 3.0GHz 95 watt. Runs great but there is one problem. When it boots uo a lot of times it will post and then go to a black screen with a small n on top of a big N with a green rectangle box beside it,course blinking Some time you have to reboot 2 or 3 times and then boots into windows fine. What is the problem causing this, any help will be appreciated...thanks
Seasonice 550 watt
4 gigs of ddr2 pc800
1 320 gig seagate os is on (windows 7 ultimate 64 bit )
1 terabyte W.D. storage
1.5 terabyte Seagate storage
Seasonice 550 watt
