- Jan 30, 2012
- South Wales
Have a look at the reply i got off Gigabyte for the poor overclock on this card.
Sent : 3/14/2012 11:52
Question : Hi i just tried to flash my bios and get this message from the bios flasher vga_bios_gv-n560oc-1gi_f6.13.23.32.42 ( BIOS is not match for your card please contact us.....)Also it wont overclock at all. Can you help me? Cheers Ian
Answer - 1199678
Answer : Hi,
What is the current BIOS version?
Please clarify how do you overclock the graphics card?
Question - 1200204
Sent : 3/15/2012 21:18
Question : Hi thanks for the quick response, the @BioS program says its GV-N560OC-1GI F32 and i have been useing easyboost. Even if i overclock it 10 mhz it crashes using Heaven benchmark. Cheers ian
Answer - 1200204
Answer : Hi,
F32 is the latest BIOS.
Which utility do you use to overclock?
Question - 1200388
Sent : 3/16/2012 09:16
Question : Is F32 the right bios for my card or have i flashed the wrong one. I believe there are two different bios's one for Samsung memory the other for Hynix memory. I have the Hynix memory version and was wondering if i have flashed the Samsung bios by mistake. Would i need to force flash. I have been trying your own overclocker Easy boost. Cheers Ian
Answer - 1200388
Answer : Hi,
We have confirmed that F32 is the latest bios version according to the SN114301009619.
You dont have to update bios.
About overclock issue , we suggest download the latest easyboost version 1.08 and set shader clock= 2* GPU clock , then press “Apply” button ,it will succeed
Question - 1202857
Sent : 3/23/2012 21:56
Question : Hi, Thanks for the reply. I have overclocked to Core 940 Shader 1880 Memory 2004. Anything higher and it will crash. The card is advertised 10%-30% overclocking ability. I can only achieve 4.4% which isnt even half of the minimum percentage decribed. Am i doing anything wrong or is it one of the batch of cards produced by you that have the problems when overclocking or playing Battlefield 3. If that is the case should i RMA the card as it is not performing as described. Cheers Ian
Answer - 1202857
Answer : Hi,
Overclock ability has been decided by GPU core and GV-N560OC-1GI has been a overclock VGA card.
GTX 56TI GPU , original core clock is 822MHz, shade clock is 1644 MHz ,memory clock is 4000 MHz, and GV-N560OC-1GI ,factory core clock is 900MHz, shade clock is 1800MHz,merory clock is 4000MHz.
You could see that GV-N560OC-1GI is already a over clock card.
So we suggest use the card in factory clock model in order to get a steady performance.
In addition ,if the card works in un-stable state for a long time ,the life cycle of the card will be shortened.
Even though it says on the box and in the specs the 10% - 30% overclocking ability has already been applied at the factory.
What do you guys think/ are they dodging the issues with alot of the 560ti cards or is this normal practice. Any advice would be helpful. Cheers Ian
Answer - 1199678
Answer : Hi,
Question - 1200204
Answer - 1200204
Answer : Hi,
Question - 1200388
Answer - 1200388
Answer : Hi,
Question - 1202857
Answer - 1202857
Answer : Hi,
