Specs:
Phenom II X4 945 + Scythe Mugen-2 Rev.B + AS5
Gigabyte MA790XT-UD4P (AMD 790X NorthBridge, ATi SB750 SouthBridge)
G.Skll DDR3 1600 9-9-9-24
NV GTX 260
Corsair VX550
So I've OC'ed my 945 to 3.405Ghz and it's completely stable at stock voltages.
CPU Core Clock: 227
CPU Core Multi: 15x --> Auto
CPU NB Multi: 9x --> 2043 Mhz
HT Link Mutli: 9x --> 2043 Mhz
DDR3 Mutli: 6.66x --> DDR3 1514
Missing anything?
So now I'm trying to bump up that CPU NB Mutliplier to 10x. That wasn't stable at stock voltages, wouldn't even POST. I bumped up the CPU NB VID voltage in the BIOS from 1.100V to 1.125V and was able to POST and get into Windows.
However, I get into AMD Overdrive, and the Voltages are at stock. Rebooted, checked CPUID Hardware Monitor, same dealio. Stability tests fail at stock voltages (calculation test errors) but they fail after 10-20 minutes when I manually up the CPU NB voltage to 1.125V in OverDrive (basically in the right direction of stability).
I tried changing other voltages around in the BIOS. They are all reset by the time I get into Windows.
Whats the problem?
NV GTX 260
Corsair VX550
CPU Core Clock: 227
Missing anything?
Whats the problem?
