- May 10, 2009
For soldering on the resistor you're going to want an iron with a fine tip. It doesn't need to be needle sharp, but small enough to just touch that one solder point. There's a sneaky method though. It looks like that resistor is connected to the top (in the pic) end of the capacitor below it. Resistors are black, capacitors are tan/orangish. You can solder on the end of the capacitor, much easier than on the resistor.
Put some leaded solder on the solderpoint and tin the wire before you try to solder the wire to it, that will make things much easier for you.
For wire, the wires in 80 pin PATA cables are perfect.
For a vcore read point, use the positive leg of one of the filter capacitors in the power section (the points near the green sticker on the photo of the rear of the card). The side with the colored block on it (on the cap) is -, the other is +, solder the read point to the + side.
