I'm running into problems running old legacy gpu's on this board, the problem seems to be some sort of bios issue with recognising the old hardware, I have two old X1600 pro gpu's that I are not playing ball!! I put the gpu in the board and from a cold boot (has been unplugged from mains power) it recognised the card and booted into windows no problem, so I restart the system only to get a blank screen,no flash screen,monitor goes onto standby??? The card is vmodded so I think maybe the mods are overloading the pcie slot somehow (highly unlikely as there not cranked up) so in goes the other card and same issue, boots on first boot but only after being unplugged from mains for a few mins, so both cards act the same modded or not, I flashed to different bios versions, enabled all the legacy options in the bios, plugged in extra pcie power for the board and it still fails to boot after the initial success unless its been left unplugged from mains for a few mins, I can't even get drivers installed as it needs to restart after its installed and then it fails to boot, and once it does fire back up its as if the card has just been installed with the "new hardware found" pop up apearing on startup. Any ideas Lol
