- May 9, 2011
- Alberta, Canada
Hi all,
I was on Facebook earlier and saw a rather disturbing post from a big name in watercooling warning users not to use plain distilled and biocide if they're planning on including the integrated waterblock from the GA-Z87X-OC Force into their loop. The post said that Gigabyte is using aluminum for the material so galvanic corrosion is a risk. As I have the GA-G1.Sniper 5 which also has an integrated block (which I'm planning to include in my loop) it got me a bit worried.
Now I've read a review of the Sniper 5 board where the reviewer completely tore down the motherboard including the heatsinks and discovered that the block is just a copper pipe with an aluminum heatsink around it (held together by thermal paste).
I'd assume that Gigabyte would know enough not to use aluminum for the piping in their blocks. I'm also assuming that they'd use the same materials and manufacturing process for both of their boards considering they came out at around the same time.
The post has since been deleted, and I'm guessing it's because they realized that the aluminum doesn't actually come into contact with the water, though I can't be sure. Does anyone know for sure if they're copper or not? I'm not at home so I can't check the board physically.
I've also reached out to Gigabyte but have yet to receive a response.
Thanks in advance!
Thanks in advance!
