- Sep 7, 2013
So my I brought my Duron out, and discovered the heatsink (clip type) clip was on backwards which put a lot of pressure on one side of the die becasue the heatsink wasn't in full contact with the core. (That would explain the hot temps )
Now I heard metal grinding sounds when I was removing the heatsink, and sure enough the die's edge has been shaved off badly....
I am assuming it still works, but before I test it, I want to know if glue will help prevent more die damage?
I have this Lepage 100% glue: http://lepage.com/100glue/TDS/100Glue.pdf says it's good up to 80*C for short periods of time, and 50*C otherwise.
I will try to keep the CPU under 50*C anyway. I might find a better fan for this heatsink (avc 112C81) since it didn't too bad in thermal tests, if it sucks, I'll be hunting for a better one.
Either way I worried about more die damage..
Images are best I can get
