- Jun 22, 2002
- Asheville, NC
i think- though im not sure... that thermal tape needs to melt a little so it can get the optimal thickness for heat transfer and that if you just had it on there as a tape it would not be as effective... thermal tape and goop stuff (as2/3) are applied to fill up VERY small scratches and "valleys" in that both the HS and CPU/GPU/Memory have... it just gives you more surface area... on memory it is obviously more impoortant to have it stay on though... you might want to go to your local radio shack get some of their thermal paste and try just that... if you put the right ammount on it is stickyenough that they stay on... i would put some electrrical tape or something like that on the card below for a lil while just to make sure if one falls it dosnt short anything out.. they may not stay on if they are copper though... i cut up an old 100mhz HS that was aluminum so it worked for me
