Why would you buy a hold over card and then get a 7970 when you already have the money for a 7970. Makes ZERO sense financially.
As ED said....... wasting 300 bucks on a hold over is not a good plan.
Don't bother with Canada Computers,
Order this http://www.newegg.ca/Product/Product.aspx?Item=N82E16814161412
while they are instock
That 7970 is a steal at $359. You need to shake the etailer preference, save $40 and get that 7970 that Xeon linked. I reviewed one...its a solid 7970, no doubt.
Darren, either go big and buy a 7970, or go home. You are blatantly wasting what money you have by doing otherwise.
Q.F.T.Use cash to buy a prepaid credit card, use credit card to buy video card?
It's a waste of money to buy a holdover card, it really is.
Or get a 7950 from there for $50 less that performs the same...As mentioned in one of a couple threads we discussed GPUs in the past, even with a single 1440p monitor, you will want the 3GB of vRAM. We also discussed the performance teirs a couple of times as well. You have the resources Darren (your many threads)... take a look back at 'em and use them for a reference, ehh?I want a GPU though.. :/ And Xeon, I can't buy from the internet. I would nab it if i could, but i can't.
edit: I found this? http://www.canadacomputers.com/product_info.php?cPath=43_557_559&item_id=048807 that would work too. and not buy a 7970 later.
I believe this would also do just fine: http://www.canadacomputers.com/product_info.php?cPath=43_557_558&item_id=059124
Won't it?
We are leading the horse to water... . He will purchase what he will purchase as we have seen the past couple months.
*ninja'd by ED
Debit card has a limit of 50$/day do you think i haven't already looked into this?
IMHO, your best bet in your price range at that store: http://www.canadacomputers.com/product_info.php?cPath=43_557_558&item_id=059644 , and not buy a 7970 later.
Though I still like Bobnova's suggestion the best: use your cash to buy a prepaid credit card and get the 7970 @ Newegg.
