Good RAM for 2700x B450 Tomahawk?
Look at the memory support list for your motherboard. ;)
I'd stick with something around 3200 mhz.
and how many more fps would i get for this double price?
depends... not worth double the cost though.
sticks must be installed to 1-3 or 2-4 or 1-2 slots?
for dual?
You can see this in the manual for your board, page 4 (EDIT: and page 29). Slots A2/B2.
hmm, but why is it not in the list ?
have you chosen it randomly by the looks and feels?
this ram will stuck at default 2133 clocks
All I managed to find it this
Crucial BLS8G4D32AESBK.8FE 3200MHz 3200 MHz Micron E 1.35v SINGLE 8GB √ | √ | √
but this is only 8 GB single rank ram and does not match perfectly 8FE
https://www.1a.lv/ru/datoru_kompone..._lt_gray_8gb_3200mhz_cl16_ddr4_bls8g4d32aesbk
Vendor
Model
RAM Speed
Supported Speed
Chipset
Voltage
Side
Size
1 | 2 | 4 DIMM
HyperX HX433C16PB3K2/32 3333MHz 3333 MHz SK hynix C 1.35v DUAL 16GB √ | √ | √
HyperX HX433C16PB3K2/32(Profile2) 3000MHz 2933 MHz SK hynix C 1.35v DUAL 16GB √ | √ | √
https://www.1a.lv/ru/datoru_kompone...cl16_hyperx_predator_kit_of_2_hx433c16pb3k216
KINGSTON 16GB 3333MHZ DDR4 CL16 HYPERX PREDATOR KIT OF 2 HX433C16PB3K2 / 16
0.511.522.533.544.55( 2 )
Product code: HX433C16PB3K2 / 16
so this mean it wont be clocked to the max unless 32GB is in?
I want to get 16 GB only
New Ballistix 3200 CL16-18-18 are based on Micron. It's inexpensive and well performing memory which should work on all motherboards.
https://www.1a.lv/ru/datoru_kompone...b_3200mhz_cl16_ddr4_kit_of_2_bls2k8g4d32aesbk
I have 4x16GB of this stuff right now and works fine @XMP 3200 on Intel and AMD.
These one should work too:
https://www.1a.lv/ru/datoru_kompone...cl16_hyperx_predator_kit_of_2_hx432c16pb3k216
https://www.1a.lv/ru/datoru_kompone...b_16gb_3200mhz_ddr4_kit_of_2_f43200c16d16gtzr
https://www.1a.lv/ru/datoru_kompone...0mhz_cl16_ddr4_xmp2_kit_of_2_f43200c16d16gvkb
Check if product number is on QVL of your motherboard but I guess that shouldn't be a problem on all of them.
