- Mar 9, 2008
Hi to all
Eric here,
Thanks for taking the time to read the post again . I tried to include the most info about my system as I could. This is an update
I am using this system for roughly 8 to 24 hours at a time to encode my dvd collection to apple tv h.264 – I-touch format using handbrake 0.9.2.
My system contains the following –
Case - Thermaltake Armor Black, Aluminium Front
Fans for case as follows
Side 25 cm - ( 1 installed)
Front 12 cm - ( 1 installed)
Rear 12 cm - ( 1 installed)
Rear 9 cm - ( 1 installed)
Top 9 cm - ( 1 installed)
Motherboard = MSI P965 Platinum, P965, Socket-775 – with latest V1.8 bios.
Processor = Intel Core 2 Quad Q6600 2.4ghz go stepping processor
CPU Cooler = Arctic Cooling Freezer 7 Pro
Ram
Corsair TWIN2X 6400 DDR2, 2048MB CL5 - 800 MHz ( PC2-6400 ) – Default timing and voltage is 5.5.5.18 & 1.9 V
Corsair TWIN2X 6400 DDR2, 1024MB CL5 - 800 MHz ( PC2-6400 ) – Default timing and voltage is 5.5.5.18 & 1.9 V
(Totalling 3gb ram)
Graphics card = Point of View GeForce 8800GTX 768MB,
PSU = Seasonic S12 Power supply 500W, 120mm
O/S = Microsoft Windows XP Pro – latest SP2 and updates.
Storage
Hard Drives = 6 x Samsung SpinPoint T166 500GB drives
Dvd-rw’s
Samsung DVD±RW burner, SH-S183A
NEC DVD±RW burner AD-5170 IDE Black OEM,
To the overclock
I have a stable over clock on my 2.4 quad to 2.8 MHz (310fsb x 9.0)
I have ran prime95 for several hours with no errors.
To get the overclock I have added .0125 volts to the cpu & the ram is at 2.0 volts. (1.9 default)
I am trying to get it to 3.0 ghz but it keeps failing in prime 95.
Any ideas
Thanks for taking the time to read my post.
Eric.
Eric here,
Ram
(Totalling 3gb ram)
Storage
Dvd-rw’s
To the overclock
Any ideas
Eric.
