- Nov 26, 2005
- Concord, NC
If you change 'Adjust DRAM Frequency' to Manual what are your choices under 'Adjusted DRAM Frequency'?
The more I see guys struggling just to achieve a modest overclock with this Q6600 the more I feel real fortunate that I got lucky enough to pick components that are willing to play well together in the same sandbox. I feel for ya man.
These guys didn't have to touch the NB voltage until they hit around 360FSB - you're only trying to get it to 333-334MHz. I hate to say this dude but in looking at your posts you're all over the board with this overclock. You should set everything back to defaults and start over.
Before you do that try changing your timings to 6-5-5-18 and run memtest first before you prime
here is a review of the board where they got a 360 fsb with a e6600
http://www.pcstats.com/articleview.cfm?articleid=2049&page=4
and here they got a 366 fsb
http://www.neoseeker.com/Articles/Hardware/Reviews/msi_p965_platinum/11.html
eric
hi Ceegar
yes seen that they didn't have to go near the nb till around 360 i have a stable 2.88 at +0.0125 cpu-v and 2.0 volts and 480mhz on the memory i didn't have to change the nb at all i will give the memory timings a go and test with mem test.
thanks
Hi Ceegar
Eric here
I left the settings as was including the default ememory timongs and i ran memtest overnight and it passed with no errors (ran 16 times)
Eric
