I still don't believe in the nickel. I get it, though, with the corrosion and patina that develops over time on copper. I understand they electroplate it with a very thin layer, but it is still going to definitely affect thermal transfer. Copper, free machining in this industry so a little bit less than pure, has a thermal conductivity of around 350 W/m K whereas Nickel is around 90 W/m K (at 0C, so a little bit less at RT). That's giving up a lot to avoid having to clean things. I'd rather just take the block apart and clean it with a toothbrush and vinegar+salt or whatever you want to use every so often. Things need cleaned anyway, so it's just good practice to do this every so often.
I've only ever had one EK Nickel plated block before now, and it didn't seem to deteriorate. Only worked with it for a year or so... Maybe not the best measure of longevity of the coating.
