Hello, first post and I'm afraid I'm not to tech orientated, but basically I've a question about a rig I just bought for 73 pounds on ebay that I need to upgrade the graphics card and most likely the psu. I'd like to make it so I can play games like Dawn of war 1+2, Supreme Commander 1+2, Medieval Total War 2, Mark of Chaos 1+2 if possible without upgrading the mobo or anything else (hmmm). If there is anything else info wise I need to add then I'll try my best to find for you.
Its got in it...
A Alive Sata2 Glan mobo (has the pci-e x16 slot)
2x 2.2gigz amd processors
3 gig of ram over 4 cards
400w psu (though I am going to upgrade that to 500+, most likely a 650w one)
160 gig sata(2?) hard drive
and the nividia (geforce???) 7200 256meg 3d fx card which I've since found out is pants
What with all the cards on the market that are all of the same series and whatnot then I'm lost. I have read that the pci-e 2 cards from nividia are incompatible with the mobo unless I flash/flush the board or something. I am on a budget but I am willing to pay a fair amount that I don't have to upgrade for a couple of years.
Any help is really appreciated, thank you in advance
Its got in it...
