The problem is, you have an AMD processor whose memory controller is not that robust. 1600Mhz with all four sticks populated is just about the max you will get out of it. That said, did you try to add more voltage to the sticks? Raise NB voltage?
Hopefully an AMD person will swing by and help out... its not my forte.
Why are you trying to lower the CAS from 9 to 8? Like ED suggested, you'll have to raise the DRAM and / or vNB in order to lower the CAS (Vdimm up to 1.55-1.60V for CL8). My suggestion is to just leave the timings as-is, and instead concentrate on your overclock.
Typically 1.65V for 24/7 use.
I feel obligated to point out that you'll get more performance out of 50MHz of CPU speed than dropping all the timings by 1 and/or raising the ram's speed.
That doesn't mean you shouldn't play with it by any means, but I would make sure you've squeezed every last bit of performance out of your CPU that you possibly can.
This man speaks the truth. Get all you can out of the CPU & GPU, then tinker with the RAM.I feel obligated to point out that you'll get more performance out of 50MHz of CPU speed than dropping all the timings by 1 and/or raising the ram's speed.
I can't get my RipjawsX to go anylower then 9-9-9-24 @ 1600MHz either, I guess is a limitation of our Phenoms.
