- Apr 3, 2013
I recently discovered that my GPU's (Gigabyte GTX 560) VRAM area is causing havoc with regards to thermals. My temperatures on full load is 100°C within a minute of it being on full load. So I decided to take everything out of my case and run it in the open. I put 2x 120mm fans behind the GPU (around the PCB) and the idle temp dropped from 38°C to 28°C, I ran stress test once again and it took much longer to hit 100°c then it normally would. That is just confirmation that the heat is coming from the VRAM area of the card as seen here:
You can see here that the area where the heat is sourced from is not covered by the heatsink:
Is there anyway I can get that area in contact with the GPU's heatsink or any of heat conductor like thermal pads that would make the fan's job easier.
[UPDATE]
I've decided to go with an aftermarket cooler from Arctic Cooling. I decision to make and I'm not entirely clued up on what to look for in a VGA cooler but I've been able to narrow it down to 2 different coolers. Which of following two cool's better?
Arctic Cool Accelero Mono PLUS
http://www.arctic.ac/en/p/cooling/vga/455/accelero-mono-plus.html?c=2182
Arctic Cool Accelero Twin Turbo II
http://www.arctic.ac/en/p/cooling/vga/375/accelero-twin-turbo-ii.html?c=2182
[UPDATE]
