I have a computer build I started about 4.5 years ago. Started life with an AMD FX-8320 on a cheap MSI board with 8GB of RAM and an AMD Radeon HD7870. Over the course of it's life, I upgraded to a GTX 970 GPU, installed an H100i GTX cooler and have over clocked the CPU to 4.2GHz. The water cooler upgrade was a early 2015 milestone.
Recently, I decided to upgrade to a more current and capable processing platform. I have acquired an i7-7800X CPU, MSI X299 Tomahawk AC mobo and 16GB of 2400MHz RAM. I just got it all installed last night and noticed I had a slight cooling issue... Scratch that... A major cooling issue.
Everything was connected just as it was with the old board. Powered up perfectly. I got into BIOS and started checking out the settings. On the fan page, I noticed my temp climbing to no end. I shut it off when it reached 90C. Today I began investigating.
I tried to reapply the thermal paste which did not help. I then noticed that all of my fans are running full speed but the water pump does not seem to be working. I tried connecting it to the CPU_FAN, PUMP_FAN, and SYS_FAN headers and did not notice any improvement. I connected it directly to 5V and 12V which also yielded no results.
At this point I'm pretty sure I should just cut my losses and upgrade to a more current model. However, I was hoping to see if anyone else has had a similar issue and if there was a simple solution to it.
Thanks to all who may be able to provide me with even a little information.
