Hey guys, I've recently torn down and rebuilt my PC to get back into gaming. The issue I'm having is that I'm having some offline lag issues. ITHat led me to find my CPU was running really hot. So, I tore the thing down, gave it some fresh thermal compound, made sure everything was mounted correctly, and I got the same temps. I can't tell if the H100i's pump is working. One of the hoses starts to feel warm once the temps raise, but only near the pump, not by the radiator. Any help troubleshooting?
Here are my Core Temp readouts:
Under load:
Idle:
Specs:
i5-3570k
EVGA 660
8GB Ram
ASRock Extreme3
H100i
Under load:
Idle:
Specs:
i5-3570k
EVGA 660
8GB Ram
ASRock Extreme3
H100i
