Could you turn the retaining ring over so that the mounting legs angled up instead of down, this giving more free space between the legs and the standoffs?
No matter how many times I've reseated this thing it is still not making good contact with the CPU.
As for the difference in mounting pressure between the pre-applied paste and mounting it again with some aftermarket tim, that's a non factor. The mount that comes with the system applies plenty of pressure to get a good mount with other tim material.
I've been using all the right brackets, the little clip that goes inside the retention has two holes and the piece that allows you to pull the clip out is facing towards the center of the retention. I've installed the retention with the screws on the outside of the inner clips and I've mounted the back plate and ensured that the metal pieces on the back of the mobo were flush against it. I've inserted the water block and twisted and made sure the retention notches stay inside the water block evenly.
No Luck. I'm returning it to Microcenter tomorrow and I'll have them install the new one.
BTW I've been extremely paronoid. RealTemps always tells me my CPU temps are about 10 degrees higher than my ASUS software that came with the mobo tell me. I've hit 85 degrees and higher at times before immidiately killing all stress testing programs and cutting off my computer. Never has my computer actually shut off because of the heat. However I'm still scared and paranoid about damage I could have possibly done to my entire 1200 rig.
Is there anyway I can assure myself that I haven't done any damage to my computer without removing or touching anything again on the inside?
