- Jun 17, 2010
- Marietta, GA
I didn't like the look of the h50's mounting system...
I suppose there's a zero chance it would use the (almost) standard AMD metal backplate???It was actually quite intuitive. If important bits weren't plastic (the back plate), it would be a very nice and easy way to mount blocks.
(Some cheapie boards still use the plastic one but most have metal.)
Often it's not whether the bolt pattern is the same but whether the bolt size is the same, a problem common with cars wheels as well as heatsinks ...Don't see why it wouldn't.
I'm not an AMD user but I've used a Xigmatek Crossbow bracket with my H50 and the plastic H50 backplate with the Xigmatek cooler.
Have also used a metal Asus 1156 bracket that came with a server board and the plastic backplate from a 980x stock cooler on the H50.
The H50 came with 2 sets of bolts , fine and coarse thread.Often it's not whether the bolt pattern is the same but whether the bolt size is the same, a problem common with cars wheels as well as heatsinks ...
Not extreme performance as far as loops go, but it might give high end air a run for it's money. And if you slip an ultra high performance fan on the rad I bet nothing short of phase change will run cooler.
I actually want to try that and see what temps I get whenever I do get one to test.
Oh yeah, I refuse to run it at all without wire guards in place. I truly think that fan could lop fingers off if you happened to stick one in it while it's at full song. And the suction from it is absolutely amazing too. You really have to watch what gets in front of the suction side of it too. It makes the Delta GFB compound fan look and sound kind of wimpy.
I'll pass thanks...We should have an ocf "who can survive putting their hand in the biggest fan" competition!!!
