darkdespair55
- Apr 13, 2013
- TX/FL
At idle my CPU runs around 52c, which I know is high. Gaming it does not jump it up terribly much, it might push it to 60C.
System:
case: HAF 922
Mobo: Gigabyte UD3r
RAMHDD: 3 HDD active
DVD: 2 drives
CPU: i7-930 clock - 2.80GHz
GPU: AMD 6950 2gb xfx Black edition
PSU: 750watt (dont recall brand)
+ secondary sound card: creative x-fi fatality pro
I have the stock cooling solution of the front 200mm intake, top 200mm exhaust and rear 110mm exhaust. I am looking to add two additional 20mm fans. One of which is 67CFM fan and the other is around 30 CMF(unknown, the gift fan came off a Coolermaster scout tower). I tired putting them on the side pannel Over/Under with the 67cfm on the top spot (intake) and the 30 on bottom (exhaust) but my temp jumped from 50c to 70c over a short period of time(still at idle). I have the stock cooler on my CPU and dont wish to switch to a cooler that would require me to pull out my motherboard to install it (unless it uses the same stock mounting system I don't want to use it) Any suggestions on how to lower the operating temperature of my tower?
System:
case: HAF 922
Mobo: Gigabyte UD3r
DVD: 2 drives
