I'm going to be building a PC and I'm very interested in water cooling most of the components outside of the mosfets.
I've been reading many forums and threads all over the web and most people agree that it's overkill to water cool the RAM. I'm not too concerned with the cost and or ongoing debate in regards to what should or shouldn't be water cooled. I'm just trying to understand the proper thinking.
For the sake of debate let's assume i want to water cool the CPU, GPU, NB, SB, and RAM. I have a handful of questions that haven't been answered from the research i've done so far and i'm in need of some advice to get my understanding on par.
Assumed specs:
Cosmos 2 case
Intel i7 Sandy Extreme 2011 cpu vs i7 ivy bridge 1155 cpu
ASUS 2011 vs ASUS 1155
Nvidia Geforce GTX 580 vs 680 (single)
Undecided on RAM, but it's going to be at least 32GB (4x8gb)
1. does one need to water cool if their not overclocking? i would think that overclocking and water cooling goes hand in hand as every standard retail pc uses air cooling. I'm sure water cooling helps components last longer, perform slightly better, added aesthetics, and all around fun, but a person that isn't planning on overclocking at this moment isn't forced to have to water cool. Am i correct?
2. i thought i read that there are reservoirs and then a pump/res combo where their integrated. If I'm correct, is one option better than the other?
3. How does a person determine the size of the radiator needed to cool a component(s)? I haven't been able (maybe i misunderstood or didn't look deeper) to get a solid answer on determining the correct size. I'm sure there's a rule of thumb and that's what I'm looking for.
4. Looping. I've read multiple opinions and i'm looking for a final conclusion. I'm assuming the order doesn't matter (yet everyone seems to have a different opinion), but the quantity and types of items in a loop does matter. Am i correct?
Does a system as such need a single loop or a double loop? in all honesty i don't understand how to design a single loop vs. a double loop.
Thanks to anyone who helps this noob mature with his thinking.
Assumed specs:
Cosmos 2 case
