I'm thinking of putting a Geforce Titan into my micro-ATX case. I'd like to provide decent cooling for it (not a stock cooler), but due to the limited space it may be hard to find room for a big heatsink + fan. I want proper cooling for vid-rams and VRMs too. With these considerations, water-cooling the Titan seems to be a plausible option.
But my case allows just one 92mm radiator, and I was able to find one such product, Hardware Labs Black Ice GTX m92:
http://www.hwlabs.com/index.php?option=com_content&view=article&id=21&Itemid=2
According to an old posting,
http://hardforum.com/showthread.php?t=1510538
This radiator can handle up to 200W of heat, which is not enough for a Titan whose TDP is announced to be 250W. But then another old posting,
http://www.xtremesystems.org/forums/showthread.php?225268-Testing-the-HW-Labs-Micro-184-GTX-Rad
tells that GTX m184 radiator with 400W heat-dissipation can easily cool QX9650 CPU (130W) + N/B and S/B chipsets + GTX 295 GPU (289W) even under the full load.
So if m184 can handle more than 420W from a big CPU and an even bigger GPU, can m92 be enough to cool just one GPU of 250W TDP?
If it's not enough, is there a better 92mm radiator that can do the job? Or any better graphic card cooling solution for a small case?
Any comment/advice from a real experience with m92, or an educated guess from expertise would be appreciated.
Thanks in advance!
Thanks in advance!
