ChasR Senior Member Joined Apr 12, 2004 Location Atlanta Jan 13, 2008 #21 right click on the tray icon, select hardware, overclocking settings, 3d renderer, scan for artifacts. Last edited: Jan 13, 2008
OP NedClocker Member Joined Sep 12, 2001 Jan 13, 2008 Thread Starter #22 Thanks! I see it. How long do I let it run?
OP NedClocker Member Joined Sep 12, 2001 Jan 13, 2008 Thread Starter #23 Over 30 minutes now and no artifacts.
OP NedClocker Member Joined Sep 12, 2001 Jan 13, 2008 Thread Starter #24 Still no artifacts. How long do I let it run?
OP NedClocker Member Joined Sep 12, 2001 Jan 14, 2008 Thread Starter #25 20 hours with no artifacts found.
dfonda Senior Golfer Joined Feb 25, 2004 Location N of splat W of Torin Jan 14, 2008 #26 Your good.... its probably not the card. Either a Windows update or something is messing with that new client.
ChasR Senior Member Joined Apr 12, 2004 Location Atlanta Jan 14, 2008 #27 It should fold if there are no artifacts. Mine gives an artifact/second and will not fold.
OP NedClocker Member Joined Sep 12, 2001 Jan 14, 2008 Thread Starter #28 Thanks. Something must have changed a driver or directX and I didn't know/don't remember it. Folding raises the GPU temp a lot higher than artifacts does.
orion456 Member Joined May 31, 2004 Jan 14, 2008 #29 NedClocker said: Thanks. Something must have changed a driver or directX and I didn't know/don't remember it. Folding raises the GPU temp a lot higher than artifacts does. Click to expand... Load a previous state and see if that fixes the problem.
OP NedClocker Member Joined Sep 12, 2001 Jan 15, 2008 Thread Starter #30 Say what? Can you do that in Windows XP? Artifacts has been running over a day now. Think I'll kill it and rule that out. 105,740 seconds.
